When running workspaces pre 2022 in FME 2022.
'GeometryFilter' sorts out Points, Areas and <Unfiltered>, when I send them into GeometryFilter_4 the <unfiltered> features exit through the Area-port.
Hi @mathiku​ I'm unable to reproduce your problem. Can you attach here your pre-2022 workspace and some sample data? thanks
