Can you read in files to FME that contain special/accented characters in their filenames?
  • Jul 5, 2022 3:04 PM UTC
  • 110 views
Hi! I am trying to read into FME a series of images (jpeg/tif/png) and then match them to a different datasource and rename them using pieces of information from both sources. All works well.
But. I have some files which contain special/accented characters which aren't being read in. For example the filename below
throws an error 'Anadolu Koyu PLAN_IZMIT KÖRFEZI TO ISTANBUL.jpg' cannot be located. Please ensure the file exists and is accessible'
The common denominator in all of the errors is the special/accented characters.
My question is whether I am missing something and I can get FME to read the filenames and bring them into the workspace, or whether I need to handle these (hundreds of) files manually?
All helps much appreciated!
  • Jul 5, 2022 3:07 PM UTC
Did you test with FME 2022? It's got some fairly important improvements regarding extended characters.
  • Jul 5, 2022 3:09 PM UTC
Hi David, thanks for responding. I actually haven't, so I'll go and get downloading now...
  • Jul 6, 2022 2:10 PM UTC
Hi David, I just got IT to install the new version and sadly it's still not reading any files with accented characters in. Do you have any other thoughts?
  • Jul 6, 2022 8:35 PM UTC
In that case you may want to contact your FME reseller or Safe support.
