Can I get better performance in FME when running spatial filter with database sqlserver.
  • Nov 6, 2019 1:52 PM UTC
  • 7 replies
  • 155 views
hamdyahmed
normal reader is used not feature reader because i need to reproject data first . result writing 1000 record takes around one minute . also resources of server are almost taken by fme engine
Forum|alt.badge.img+63
Can you tell us a bit more? A screenshot of your workspace would help, along with an indication of the amount of data being read.
hamdyahmed
  • Nov 12, 2019 8:10 AM UTC
thanks for your reply. please see the attched file
Problem: - when run spatial filter transformer just simple intersection and update field in table based on this filter it takes long time to write data
1000 record in approximately 1 and half minute
See windows resource’s ( CPU, Memory)
Configuration: -
DB Engine :Sql Server 2012 and windows server 2012 . FME 2017.1
Configuration: -
It looks like you have 6 separate readers for the SQL Server data, are you using a separate reader for each table? That's probably not necessary, and a hit on performance, so try and replace them all with a single reader.
There's also 2 writers which, again, may not be necessary.
Are the parcels and boundaries in the same projection? If so, you could use a single SQLCreator with a spatial query in it to perform the spatial filtering, that might be a big gain.
sigtill
Forum|alt.badge.img+25
  • Nov 12, 2019 8:20 AM UTC
1. Upgrade to FME 2019 - this can be installed on same machine, different directory with no problems. https://www.safe.com/support/downloads/
2. Which writer? JDBC or regular?
3. Add Bulk Insert Yes:
4. Are you on wireless or wired network?
frankvandoorne
Configuration: -
I cannot see the specifications of the server in terms of CPU, amount of RAM and disk space etc. , so it is hard to tell. There must be a bottleneck.
It looks like FME Desktop is installed on the same machine as the database server. That is not a best practice. If possible, try to run the same workspace on FME installed on a different machine as the Database Server.
Furthermore, do some research if you could tune your database. Finally, I see that you write "updates" to the database. I don't know if the table you write to has extensive "triggers on update" that could have negative impact on performance. If this is the case, you could try to disable these triggers when FME starts and enable the triggers again at the end. If a trigger is very time-consuming, check to rewrite it, create some more indexes on tables, etc.
frankvandoorne
@hamdyahmed In the database, you *should* have created an unique key constraint and an index on the 'Match' Column (in your case UUID).
hamdyahmed
  • Nov 12, 2019 4:13 PM UTC
- this server specification :-
process intel xeon cpu E5-2680 v3 @2.50GHz(3 processors)
installed memory 24.0 GB
- match key is the primary key and index is already exist
- Bulk insert is off because it is update operation it is recomended by fme to off when update
- there is no update triggers in this table
why we install fme in same machine of database server because client in remote site and we think that performance will be better when in same server rather read and write through network large amount of data
