Bulk convert DGN to Shape Files
  • December 22, 2022
  • 75 views
I have thousands of dgn files that need to be converted to shape files. I want to convert each dgn into corresponding shape file. Also I want to add the DGN file name, IGDS_level_name and the elevation of the feature as attribute in shape file. Is there a way of doing it quickly.
Regards,
Krishna
dustin
Forum|alt.badge.img+30
  • December 22, 2022
This article may be of assistance: How to Convert DGN to Shapefile (CAD Levels to GIS Attributes) (safe.com)
How quickly you can convert really depends on how complex your dgn files are. The dgn file name will be stored in igds_basename, and the elevation can be extracted using the CoordinateExtractor.
I would suggest using the Generate Workspace function in FME as the starting point, then build out your attribute requirements from there.image
noradavis
  • December 23, 2022
Batch convert dgn files to separate shapefiles in ArcGIS · 2. Just about everything is possible through ArcPy. · Convert to DWG and then covert ...Our online converter of Microstation DGN format to ESRI Shapefile format (DGN to SHP) is counter fast and easy to use tool for both individual and batch conversions.MicroStation itself, because it's generic CAD tool, does not support SHP format export (import is possible). To export data to SHP format, you have to use Bentley Map (on top of MicroStation or as standalone product depending on your license).
