Best FME practice to convert JSON (as HTTP _response_body) input for a table (Postgres)
fbrws
BANNED
I need to convert:
"keys": [
<ordered list of field names>
"values": [
"<ordered list of field values, matching the keys field order>
What is the best way to do this in FME?
Input example: see attachment
Best answer by geomancer
Passing _response_body to a JSONFlattener does the trick for me.
geomancer
Forum|alt.badge.img+47
  • August 24, 2023
The ListKeyValuePairExtractor (from FME Hub) looks like a good choice here. You will have to expose the attributes afterwards.
fbrws
BANNED
  • BANNED
  • August 24, 2023
Hi Geomancer,
Thats a fast and complete answer! Thanks a lot. I will try it and report back.
Cheers
fbrws
BANNED
  • BANNED
  • August 25, 2023
The above example works like a charm. Thanks again!
But its getting a little more complicated. Instead of using a JSON file I am getting a JSON response from a RES API which I invoke with the HTTPCaller. After that I use a JSONValidator, JSONFormatter and JSONFragmenter to connect to the ListExploder, the rest is the same.
(The first part of this is from Exercise: Handling JSON - FME Web Services (imgscloudapps.com))
http_jsonConfiguration of the JSONFragmenter:
http_json3Configuration of the ListExploder
http_json4But I get an error with ListExploder:
http_json2What I am doing wrong?
fbrws
BANNED
  • BANNED
  • August 25, 2023
I get it working with the HTTPCaller in connection with TempPathnameCreator and the FeatureReader
http_json_featurereaderBut it feels cleaner (best practice, less steps) to use the response_body, although I haven't got it working yet.
What do you think?
geomancer
  • August 25, 2023
fbrws
BANNED
  • BANNED
  • August 25, 2023
Thanks again geomancer! It works perfectly. You are a genius :)
Forum|alt.badge.img+31
  • August 25, 2023
You are getting the error because the list you've exposed doesn't actually exist in the data if you have processed it using the JSONFragmenter setup pictured above.
Try a JSONFlattener instead, this should give you the lists you need.
Alternatively, you could save your http response to a file instead of an attribute, and then read that back in as JSON with a FeatureReader
geomancer
  • August 25, 2023
You're welcome, have a nice day! 🌞
fbrws
BANNED
  • BANNED
  • August 25, 2023
Thx eby! Really helpfull remarks. Your input is coming together below.
