AutoCAD Lines to Points and include Point ID
  • Sep 20, 2019 7:30 AM UTC
  • 5 replies
  • 129 views
Hello All,
Im trying to extract the points (in order) of an AutoCAD line. Ive managed to extract the points, the coordinates and do most of the workflow, but I cant get the Point ID.
In the attached, Im looking for an additional column that will give me Point IDs 1,2,3,4 etc per l;ayer.
itay
Forum|alt.badge.img+19
  • Sep 20, 2019 7:34 AM UTC
Hi @cfordigan,
You can use a Counter transformer, group by the layer (counter name = 'your layer name')
You can rename the resulting attribute in the transformer (e.i _count = ID)
Or...
Use the FME Feature Function Count in an attribute creator ( more advanced)
Hope this helps,
Itay
Forum|alt.badge.img+54
  • Sep 20, 2019 7:35 AM UTC
If you use a CoordinateExtractor to extract all coordinates to a list, instead of chopping, you can then explode the list into points, and the index of each point will be written as an attribute
  • Sep 20, 2019 12:43 PM UTC
Awesome! It works and I love FME!
Hi @cfordigan,
Or...
Hope this helps,
Itay
Thankyou! Worked
  • Sep 20, 2019 12:44 PM UTC
Hi @cfordigan,
Or...
Hope this helps,
Itay
Used the counter too. Thankyou!
