Attribute Creator - using attribute value for a new attribute name
  • September 21, 2018
  • 6 replies
  • 410 views
bgeorges
Forum|alt.badge.img+5
I would like to use an attribute value for a new attribute name using the Attribute Creator transformer, but this just not working. The new attribute is not created even if we can parameter the Attribute Creator to do so:
I am using FME 2018.1.0.1 64bits
I have found this old question with the same issue. According to the accepted answer, the issue was suppose to be fixed in FME 2017. So is the problem fixed or not?
Best answer by ebygomm
You need to expose the attribute after creation for it to be visible in the workflow. It works fine in 2018 for me
erik_jan
Forum|alt.badge.img+19
I have used this too.
The attribute seems to be created, but not exposed.
If you check the data in the Data Inspector, you will not find the attribute in the Table panel, but if you select a feature, you will see it in the Feature attributes panel.
Using an AttributeExposer to expose all created attributes will help showing the attributes and their values.
Forum|alt.badge.img+39
  • November 26, 2019
I am having the same problem. I tried attribute exposer but I don't see the attributes that were (supposedly) created in the "Attributes to Expose" dropdown. I'm using FME 2019.
Thank you,
Randy
  • November 26, 2019
Thank you,
Randy
You have to manually type the attributes in, they won't be selectable in a drop down
harmen_kampinga
No, that's not the way FME should work, to my opinion... then there is no dynamic solution anymore.
  • January 22, 2020
If you are writing dynamically, there is no reason to expose attributes in the workspace
