Arithmetic Editor - Math Operator (x?y:z) - Failed to evaluate expression
  • Apr 5, 2018 11:02 PM UTC
  • 108 views
Forum|alt.badge.img+3
Why doesn't this work?
@Value(SP)=FD?@Value(PCT):0
If the value of attribute SP is FD, then use the value of attribute PCT, otherwise 0. I tried using 'FD' and "FD" too.
2018-04-05 22:58:55|   8.1|  0.0|WARN  |AttributeManager_19: TCL Error Message:
2018-04-05 22:58:55|   8.1|  0.0|WARN  |     invalid bareword "FD"
2018-04-05 22:58:55|   8.1|  0.0|WARN  |     in expression "FD=FD?10.0:0";
2018-04-05 22:58:55|   8.1|  0.0|WARN  |     should be "$FD" or "{FD}" or "FD(...)" or ...
2018-04-05 22:58:55|   8.1|  0.0|WARN  |AttributeManager_19: Failed to evaluate expression 'FD=FD?10.0:0'.  Result is set to null.
  • Apr 5, 2018 11:14 PM UTC
Hi @mikek, in math expressions, you can operate only numeric values.
If you need to create a new attribute which could have one of two different values (@Value(PCD) or 0 in this case) depending on a condition whether an attribute value (@Value(SP)) is equal to a literal string 'FD', consider using conditional value setting in an AttributeCreator or an AttributeManager.
