Apache Parquer Writer does not write DateTime columns properly
  • Dec 14, 2024 10:33 AM UTC
  • 157 views
ahuarte47
Forum|alt.badge.img+4
Hi community, I am using FME Workbench 2024.1 to create parquet files. Those files contain DateTime columns.
It seems as those DateTime columns are missing a codec flag in order to enable the loading in other software (Dremio in my user case).
Using parquet-tools we can see the problem:
java -jar parquet-tools-1.9.0.jar schema ~/Downloads/part0.parquet
can not read class org.apache.parquet.format.FileMetaData: Required field 'codec' was not present! Struct: ColumnMetaData(type:INT64, encodings:[RLE_DICTIONARY, PLAIN, RLE], path_in_schema:[_transaction_ts], codec:null, num_values:66, total_uncompressed_size:95, total_compressed_size:113, data_page_offset:35, dictionary_page_offset:4, statistics:Statistics(max:EC 90 D1 36 42 42 10 18, min:EC 90 D1 36 42 42 10 18, null_count:0), encoding_stats:[PageEncodingStats(page_type:DICTIONARY_PAGE, encoding:PLAIN, count:1), PageEncodingStats(page_type:DATA_PAGE, encoding:RLE_DICTIONARY, count:1)])
I include here a small parquet example with two datetime columns (last_update and _transaction_ts).
Please, can you help me?
Is it a bug? Do I have to define an extra setting in my FME workflow?
Thanks in advance
itsmatt
Forum|alt.badge.img+48
  • Dec 20, 2024 7:24 AM UTC
Which version of Parquet are you using when writing?
I looked up the error and found this thread: https://github.com/pola-rs/polars/issues/3929
There is a suggestion to made sure you’re using version 2.0 and to try a different compression method (Snappy?). Seems a bit strange that a different compression might help in this case but worth a shot.
debbiatsafe
Forum|alt.badge.img+24
Posting the resolution publicly in case it helps another user.
FME outputs timestamp data type (DateTime) columns with nanosecond precision (https://docs.safe.com/fme/2024.1/html/FME-Form-Documentation/FME-ReadersWriters/parquet/User-Attributes.htm) for the Apache Parquet writer format.
FME 2024.2 added support for allowing a choice of writing timestamps with either nano-, micro-, or millisecond precision for Parquet.
The output files could be loaded into Dremio after specifying timestamp_microsecond as the data type for timestamp columns in the Parquet writer.
itsmatt
  • Jan 8, 2025 8:27 AM UTC
Awesome thanks for sharing
