AGOL feature service writer not working correctly
markcoopersdc
Hi
Im using the AGOL feature service writer to write to our AGOL account but it is not working correctly. The workbench reports that it has been successful with the correct number of features. However, when you open the item in AGOL, there are features missing. The last one I tried had 80k reported to have written but only 4k in AGOL!
If I use write a fgdb locally and then the ‘ArcGIS Online Connector’ transformer to upload the file and another to publish it, it works fine. However, I cant work out how I could use this to do updates to the hosted feature service when the data changes (Ive got this sorted with the writer)
Im using FME 2023.2 (dont really want to upgrade until 2025.1 is out as its a proper pain to upgrade server) but if there is an issue with the older version of this transformer I will.
Does anyone know why the writer is not working but the connector is? This data is business critical so I need to ensure that it is correct.
Thanks
crutledge
Forum|alt.badge.img+28
  • March 18, 2025
Hi ​@markcoopersdc
I have run into this as well and had to work around it while never really figuring it out. So I am curious to see what happens here.
Have you ever tried adjusting the Feature Per Request in the advanced settings?
nielsgerrits
One way to solve this is to reupload the data under the hosted feature layer in AGOL. See Issue with Updating/Truncating AGOL Feature Service via FME Flow – "413 Request Entity Too Large" Error
