Adding a map of the features in HTMLReportGenerator
  • Aug 26, 2024 10:34 AM UTC
  • 5 replies
  • 317 views
ammar.shaarbaf
Forum|alt.badge.img+4
Is it possible to add a map of a feature/layer in an HTML report using the HTMLReportGenerator?
Thank you in advance
Best answer by nielsgerrits
Yes.
nielsgerrits
Forum|alt.badge.img+67
  • Aug 26, 2024 12:39 PM UTC
Yes.
danilo_fme
Forum|alt.badge.img+58
  • Aug 26, 2024 12:44 PM UTC
Yes.
Great answer.
ammar.shaarbaf
Yes.
Thank you very much! :)
s.jager
Forum|alt.badge.img+27
  • Aug 26, 2024 1:14 PM UTC
From the 4 pre-configured options, the other 3 either require an access token, or very clearly state something about “for development purposes only” (so probably need an access toen as well, or something...).
If you want to have a bit more control (or, like me, simply do not want to use any of the proprietary versions...), it is not that difficult to add a Custom HTML section, and use Openlayers and a bit of Javascript. Getting the geometry from the features is easy enough using a GeometryExtractor set to GeoJson. This way you have full control over the background maps as well.
It’s the solution I chose instead of one of the 4 preconfigured ones. So something like this:
<link rel="stylesheet" href="https://openlayers.org/en/v6.15.1/css/ol.css"/>
<script src="https://openlayers.org/en/v6.15.1/build/ol.js"> </script>
<div id="map" class="map" style="border: 2px solid black; widht:500px; height:500px;"></div>
<script>
function getBufferedExtent(olFeature)
var geom = olFeature.getGeometry();
var ext = geom.getExtent();
var buffer = ol.extent.buffer(ext, 50);
return buffer;
function zoomTo(olFeature)
var zext = getBufferedExtent(olFeature);
map.getView().fit(zext, map.getSize());
var brtachtergrond = new ol.layer.Tile({
visible:true,
source: new ol.source.XYZ({attributions: '&copy; <a href="https://www.pdok.nl" target="_blank">PDOK</a>',
url: 'https://service.pdok.nl/brt/achtergrondkaart/wmts/v2_0/standaard/EPSG:3857/{z}/{x}/{y}.png',
projection: 'EPSG:3857'
var perceelSource = new ol.source.Vector();
var perceelLayer = new ol.layer.Vector({
source: perceelSource,
style: new ol.style.Style ({
stroke: new ol.style.Stroke({ color: 'rgba(00, 00, 150, 1)', width: 2}),
fill: new ol.style.Fill({ color: 'rgba(00, 00, 150, 0.25)' })
var pol = @Value(_GeoJson);
var format = new ol.format.GeoJSON();
var perceelFeature = format.readFeature(pol);
perceelSource.addFeature(perceelFeature);
var scaleLineControl = new ol.control.ScaleLine();
scaleLineControl.setUnits('metric');
var map= new ol.Map({
layers: [brtachtergrond,
perceelLayer
target: 'map',
controls:ol.control.defaults({attributionOptions: ({collapsible: false}) }).extend([scaleLineControl]),
view: new ol.View({ projection: 'EPSG:3857',
center: [650946, 5788365],
zoom: 5
zoomTo(perceelFeature);
</script>
Note the line
_GeoJson is the attribute I used to extract the geometry to, using a GeometryExtractor, with GeoJson as Geometry Encoding.
nielsgerrits
Yes.
Great answer.
I could think of a lot of additions, but the question was clear so is the answer 😁 but I’ll admit it is a bit sparse.
This is an answer to bookmark! Working samples are the best.
