Add sequence number to unknown count attribute split list
fme4fsj
I have a DBF file that has a list of ID's, seperated by a comma, in a single field.  I also have a field that gives me a count of the number of IDs.  I need to add an attribute that gives each exploded InterimID (see example below) their sequence in the list.  I can split that list, explode it to get each ID and I thought about using an AttributeValueMapper with the _List(0) number, but how do I add a value as a sequence attribute to each exploded ID when the count could be anything?  Am I on the wrongtrack?
Example:
Line_ID     StartID     InterimID             NoInterimID     EndID
1234          789          234,543,756               3                 8976
Is this a clear enough example?
  • April 22, 2013
not quite sure I understand what you need here, to be honest. Could you perhaps post an example of what you have (input) and what you desire as output? Also, please specify if which version of FME you're using.
I guess you have already looked at the AttributeSplitter, ListElementCounter and ListIndexer?
David
Forum|alt.badge.img+54
  • April 22, 2013
If you're using the attribute splitter to create your list, then using a list exploder the _element_index attribute gives the sequence of each exploded ID
fme4fsj
  • April 22, 2013
Thanks for the quick replies.   I had been using FME 2010 but just upgraded to FME2013 still not familiar with all the changes though.
I was just thinking I should have put what I wanted as output.  From the  input.:
I'd like as output:
Line_ID    ID        Sequence
1234          789              1            (fromStartID)
1234          234               2           (from 1st InterimID)
1234          543               3           (from 2nd InterimID)
1234          756               4            (from 3rd InterimID)
1234         8976              5           (from EndID)
Does this make things clearer?  I am trying this with the AttributeSplitter and Counter.   I haven't looked at the ListElementCounter and ListIndexer.  I will take a look now..
Thanks for the pointer.
  • April 22, 2013
Ok
I would concatenate start ID, interim ID and End ID to get a new attribue with value
789,234,543,756,8976
Attribute splitter  to split that attribute into a list, then a list exploder. The list exploder will add an attribute named _element_index which will give the order of the ID in the sequence (note that the order starts from 0 rather than 1)
mark2atsafe
Forum|alt.badge.img+59
I'm with @EGomm on this - concatenate the attributes together (StringConcatenator) split them up (AttributeSplitter) then separate out the list (ListExploder).
fme4fsj
  • April 22, 2013
Thank you all for your quick replies on this especially @EGomm as that seems like such a simple solution.  And I do prefer simplicity.   I'm trying it now.
