3D PDF Labels
  • March 13, 2014
  • 97 views
Is it possible to output labels for a 3D PDF?
I've created a 3D surface map of a reservoir, and I want to include height labels for the contours shown on the map. I've used the labeller transformer to create labels for the contours, and when I view the contours and labels in the inspector / visualiser within FME, they look fine, but when i write them to PDF, they get converted into point features.
Are labels for 3D PDF outputs possible?
Many thanks.
Best answer by david_r
have you tried the TextStroker?
David
  • March 13, 2014
David
  • March 13, 2014
Thanks - the TextStroker worked perfectly in conjuction with a 3DForcer to put the labels at the correct elevation.
Thanks again.
Richard
