No schema when running multiple processes
  • July 15, 2019
  • 5 views
Workbench contains 7 individual sql queries that produce shapefiles.
When run all together six work, but one of the processes fails with a no schema error. However, the process that fails works when run on its own.
What could be the problem?
Thanks.
chrisatsafe
  • July 18, 2019
Hi @promking,
Are you able to share a bit more information about the translation (like the translation log, screenshots of the canvas/parameter windows)? Additionally, what Attribute Definition are you using on the writer?
