I am following the example of the village that can be found here: http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/jsontemplater.htm
my root is the following:
"title": "Atlas de l'immigration - Exemple d'atlas dynamique",
"layers": [
fme:process-features("LAYERS"),
my sub names LAYERS is the following:
"name": fme:get-attribute("fme_basename"),
However I got this error:
|JSONTemplater(XMLTemplaterFactory):The following error occurred near line 5, column 5 of the query:
|JSONTemplater(XMLTemplaterFactory): invalid expression: syntax error, unexpected "]"
I thought I was following the doc example carefuly. Why this error?
