Retrieve some values from XML
oliver.morris
Forum|alt.badge.img+12
Hi, I am trying to pull some content from XML and making a mess of it.
I use the XMLFragmenter extract from this:
<?xml version="1.0" encoding="UTF-8"?><wfs:FeatureCollection xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:workspace_wfs="workspace_wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" numberOfFeatures="5" timeStamp="2019-10-11T13:52:44.446Z" xsi:schemaLocation="http://www.opengis.net/wfs https://geoserver.xxx.com/geoserver-cluster/schemas/wfs/1.1.0/wfs.xsd workspace_wfs https://geoserver.xxx.com/geoserver-cluster/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=workspace_wfs%3Abasin_models"><gml:featureMembers><workspace_wfs:basin_models gml:id="basin_models.48"><workspace_wfs:changedetect_date>2019-09-11T09:33:46Z</workspace_wfs:changedetect_date><workspace_wfs:changedetect_uuid>46af9f38-5edd-4b33-8f15-6cadafcc5c40</workspace_wfs:changedetect_uuid></workspace_wfs:basin_models><workspace_wfs:basin_models gml:id="basin_models.49"><workspace_wfs:changedetect_date>2019-09-11T09:33:46Z</workspace_wfs:changedetect_date><workspace_wfs:changedetect_uuid>c6fa6e9a-e2a5-4815-8df3-0a05a4e9bbe1</workspace_wfs:changedetect_uuid></workspace_wfs:basin_models></gml:featureMembers></wfs:FeatureCollection>
elements to match:
"workspace_wfs:changedetect_uuid"
This gets me to here:
<?xml version="1.0" encoding="UTF-16"?><workspace_wfs:changedetect_uuid xmlns:workspace_wfs="workspace_wfs">46af9f38-5edd-4b33-8f15-6cadafcc5c40</workspace_wfs:changedetect_uuid>
but what I really just want is the guid in the attribute.
What do I use to extract this?
Many Thanks
Oliver
Best answer by ebygomm
If you go into in Flatten Options tick Enable Flattening you can get your result from the XMLFragmenter
bruceharold
Forum|alt.badge.img+17
  • October 11, 2019
Hi, you can use the XML reader directly, like the attached.
oliver.xmlxml2none.fmw
oliver.morris
  • October 11, 2019
thanks @bruceharold I am reading this in from an HTTPCaller and so dont have that luxury.
oliver.morris
  • October 11, 2019
I managed to do it, I dont quite now how but it populates a field.
Forum|alt.badge.img+31
  • October 11, 2019
bruceharold
  • October 11, 2019
Yeah by trial and error me too.
xml2none.fmw
oliver.morris
  • October 11, 2019
thank you @egomm that works! have a good weekend.
