Hi! I am getting a warning that FMEFlow is affected by CVE-2024-56337. I am running FME Flow 2023.1.1
Is this correct?
Is there a fix or are these CVE not applicable?
Best regards
/Kim
Is this correct?
Best regards
/Kim
Best answer by zoe.forbes
Hi Kim,
I can confirm FME Flow is not affected by CVE-2024-56337, CVE-2024-50379 or CVE-2025-24813, since these vulnerabilities require write access to the default servlet which Flow doesn’t provide.
Sorry it took so long for you to get a response to this!
Thanks,
Zoe
Edit: Since this response, we’ve published an article on CVE-2025-24813’s impact on FME.
