Hi there, can anyone please help me how can I filter some record that have a particular word. For example, I would like to filter all the road name starts with 'The ' (e.g. The Meadow but not like 'Theodor road'. If I use contains/begins with in the tester, it gives me all that have string part 'The'. I never used Regex editor. A good response will be highly appreciated. Thanks in advance.
How to filter string by using a word, not part of string
Best answer by birgit
The tester really should work for this. You need to use the begins with option on the tester and the test clause should be "The " (with a space behind it). That way you will only get The Meadow and not Theodor road.
