I am extracting Shapefile. Coordinates are reversed. LONGITUDE, LATITUDE. I need to invert to latitude, longitude.location original is in Brazil but show in Atlantic Ocean. reading -54,-31 but correct is -31,-54 degreess. How do I fix the problem?
Best answer by danilo_fme
Hi @marcelocopetti
I suggest you to use the transformer CoordinateSwapper:
Thanks in Advance,
Danilo
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
