Feature grouping based on string value
boubcher
Forum|alt.badge.img+11
Hello there
the data we have looked like this as a sample
steaure calssificationas you can see each end value of the r-name is the start of the next feature
the goal is to group them based on this relationship
end result should look
fature_grupingThanks
Forum|alt.badge.img+35
  • February 1, 2022
You can do this with adjacent attribute mapping. If you split r_name by the hyphen, you can then use a conditional statement to assess whether the end of the previous value matches the start of the current value. If there is a match, use the group id from the previous value, otherwise increment by 1
boubcher
  • February 1, 2022
@ebygomm​
Thanks for your replay
I cant find the transformer could u please share the complete name
just a note the features are not coming in order all the time, is this will work
Thanks
  • February 1, 2022
boubcher wrote:
@ebygomm​
Thanks
The transformer is an AttributeCreator, you could also use an AttributeManager. This workflow would rely on the features coming through in order.
  • February 1, 2022
If you can't rely on order this is another approach using the excellent ListCombiner custom transformer. You would need to add 1 to the Group ID if you wanted group numbering to start from 1 instead of 0
  • February 2, 2022
Example
