How to export multi geometry join filed in smallworld to shape files using FME?
  • September 26, 2017
  • 11 views
Example: MagikSF> vl.collections[:l!foreign_facility].at(45281100).lg_scale_annos $ a sw:db_set MagikSF> print(!) $ db_set: l!for_facility_lg_scale_anno226:(gis_id(1160218,959604322,45281108)) l!for_facility_lg_scale_anno226:(gis_id(1160218,959604322,45281110)) MagikSF>
foreign_facility is joined with other large scale anno collection and in smallworld it is returning as ds_set.
while exporting that, it is going as char and taking "db_set" as value in text format which is not correct .
how to export this particular field.
erik_jan
Forum|alt.badge.img+17
What SamllWorld reader are you using?
The Spatialbiz plugin for SmallWorld has an option to read all geometries separate or as an aggregate geometry (with the name of the geometry as a trait).
