Is there any way or tool for Version Control of FME Workbenches?
  • July 8, 2014
  • 5 views
Is version control possible in FME? Can someone suggest any tool which can be used to check/compare different versions of same FME Workbench.
Thanks in advance.
  • July 8, 2014
any source control system should work with FME Workbenches since they are XML-based.
So systems like Subversion or git etc work fine.
David
