How can FME merge several kml in a single one keeping tree file structure in Google earth?
  • August 7, 2013
  • 84 views
Hi, My reader is a shapefile which is transformed to ten kml files. Each folder Output is composed by 2 files, one file (included all hierarchical organisation folder: event type,country,year, month, event) and one placemark (included coordinate, styler...).
So I would like to merge all these kml files in a single one in keeping the structure I have (event type,country,year, month, event). Is there a tool to do that?
Thanks in advance for your help.
Regards
Arnaud
Best answer by arnaud
Apparently it can be done by going in Google Earth, making a file, drag and drop all kml and save this file. Is it possible to do it in FME?
The problem is after that the final kml is too heavy to handle in Google Earth (15 Mo). Is there a trick to handle such big file?
  • August 7, 2013
