Dear all,
I am looking for a solution to generate a raster based on observations (points), for example temperature and humidity. The raster should cover the entire country (polygon), and preferably interpolated with kriging or Inverse Distance Weighting. Is this possible in FME? I came closest with the rasterDemGenerator, but doesn't give a very satisfying result. Any input is appreciated!
Cheers,
Willem
