can i split 3d entity in skp (sketchup) file?
  • June 6, 2018
  • 15 views
i build a 3d buildings scene in sketchup, when i convert it to 3d tiles, i found there is only one feature in b3dm, i can't divide different buildings each other, can i split 3d entity in skp file ? or any good solution to solove it ?
thanks!
daveatsafe
Forum|alt.badge.img+19
  • June 7, 2018
Hi @chiangbt,
A Sketchup file is read in as a single aggregate feature. You can use the Deaggregator transformer to break it up before writing to b3dm.
