Create polygons from lists
This seems as though it ought to be really simple but I can't figure out how to do it.
I have a number of text files which each define a polygon by listing the coordinates of its vertices. I'd like to build polygons from the coordinate lists.
Usually I'd use the VertexCreator to build points/polygons but I can't figure out how to get it to iterate through a list of variable length.
Some of the lists are also quite long (20+ coordinates) and it seems there should be an easier way than adding 20+ VertexCreators in series!
  • November 22, 2018
Some vertex lists can be automatically parsed by FME, if they conform to some standard such as WKT.
Could you please post an example of such a coordinate list here?
  • November 22, 2018
The solution depends on how the coordinates are listed in a text. Could you please post a sample text that illustrates the format of coordinates list?
@david_r thanks for getting back to me. Here's a list:
PLY/1,54.3671208915,10.1422463646
PLY/2,54.3700921435,10.1422584956
PLY/3,54.3700947237,10.1537959675
PLY/4,54.3693817722,10.1537945973
PLY/5,54.3693818426,10.1541095477
PLY/6,54.3688144656,10.1541084576
PLY/7,54.3688143977,10.1537935091
PLY/8,54.3671234716,10.1537838354
This is actually part of the metadata of a BSB file. The BSB reader in FME doesn't seem to pull in much of the file as attributes so I'm reading it in as a text file to access this data and using a stringsearcher to identify these coordinate pairs. So, this is part of a file with lots of different information in it.
@takashi I've posted a sample below from one of the files. It's part of a BSB header so contains all the standard BSB header info but the BSB reader doesn't read this data in. Therefore I'm reading it in as a text file. I'm trying to extract the PLY polygons.
  • November 22, 2018
We'll need a bit more context, how is the list represented in your workspace?
gio
Forum|alt.badge.img+15
  • November 22, 2018
@erinjayaustin
if they are ordered would a LineBuilder not suffice? Group by/connection break attribute = fme_feature_type
(make sure last coord = first coord of course) If they close they become polygons.
I'm using 2 string searchers to extract the x-coords and y-coords, which creates a list of the subexpression matches. I've attached an image of what the 2 lists look like for this feature.
I'd like to plot the points (x-coord{n}.part,y-coord{n}.part).
  • November 22, 2018
Here's a possible solution using the PythonCaller:
def GeneratePolygon(feature):
    x_coords = [float(x) for x in feature.getAttribute('x-coord{}.part'or []]
    y_coords = [float(y) for y in feature.getAttribute('y-coord{}.part'or []]
    feature.addCoordinates(zip(x_coords, y_coords))
Add a LineCloser after the PythonCaller.
Thanks. I'll give this a go and see how I get on.
  • November 22, 2018
Other approaches.
You can convert the two lists to a single structured list consisting of two members (e.g. "_coord{}.x" and "_coord{}.y") with the AttributeManager (Rename Action), then explode the list (ListExploder), create vertices (VertexCreator), build a line (LineBuilder) and finally close the line to form a polygon (LineCloser).
Alternatively, the JSONTemplater with this template expression creates a GeoJSON object representing a polygon. You can replace it with a polygon geometry using the GeometryReplacer (Geometry Encoding: GeoJSON).
let $xs := fme:get-list-attribute('x-coord{}.part')
let $ys := fme:get-list-attribute('y-coord{}.part')
return
    "type" : "Polygon",
    "coordinates" : [
            for $i in (1 to count($xs))
            return [xs:double($xs[$i]), xs:double($ys[$i])],
            [xs:double($xs[1]), xs:double($ys[1])]
  • November 22, 2018
Be aware that the script would throw an error If the Python Compatibility was set to 3.x. with Python 3.x, you should modify the last line. e.g.
    feature.addCoordinates([(x, y) for x, y in zip(x_coords, y_coords)])
takashi wrote:
Other approaches.
return
    "type" : "Polygon",
    "coordinates" : [
Thank you very much @takashi, this worked for me!
I couldn't get this to work, but I don't know Python very well! When I have a bit more time I'll have another go as I like to be able to understand everything in my workspaces! Thank you for the help.
runneals
Forum|alt.badge.img+20
  • July 31, 2020
Put together this transformer that makes a line, but I think making a polygon would be just as simple :) https://hub.safe.com/publishers/runneals/transformers/listlinebuilder
For anyone else trying to solve this, I had a similar issue where I wanted to create 40 simple rectangular polygons without using a reader. I came up with the following solution, which isn't particularly elegant, but it gets the job done! I hope I've covered all the parameters that matter.
Creator
  • Number to Create: 1
AttributeManager
  • Output attribute: coordinates
  • Output value: text with x0 y0,x1 y1,x2 y2,x3 y3, x4 y4, ... , x0 y0 on each line (first and last coordinate pairs are the same)
AttributeSplitter
  • Attribute to split: coordinates
  • Delimiter or Fomat String: [new line]
  • List Name: _coordinate_list
ListExploder
  • List Attribute: _coordinate_list{}
  • Element Index: _polygon_index
AttributeSplitter_2
  • Attribute t split: _coordinate_list
  • Delimiter or Format String: [comma]
  • List Name: _coord_pair
ListExploder_2
  • List Attribute: _coord_pair{}
  • Element Index: _polygon_coord_index
AttributeSplitter_3
  • Attribute to split: _coord_pair
  • Delimiter or Format String: [space]
  • List Name: _x_y
VertexCreator
  • Mode: Replace with Point
  • X Value: _x_y{0}
  • Y Value: _x_y{1}
LineBuilder
  • Group Processing: Ticked
  • Group By: _polygon_index
If the LineBuilder outputs a Line, your first and last coordinates aren't the same. Otherwise you should have polygons good to go.
