@soly do you have a small example that members of the community can work with? Can you clarify whether you're using TopologyBuilder or NetworkTopologyCalculator?
i think i had misunderstood from me of the output i found that he gives me same number as table,i used topology builder then network topology calculator ,my target to reach which connected to which nodes and if we have common id i mean as id 11 so any node connects to should be has the same network id
id
network_id
id 11
1
id 12
1
id 15
1
id 20
1
id 11
2
id 18
2
id 17
2
id 19
2
id 11
3
my source is DGN file ,just i wanted to show u ,how it looks like
but i found nw , he gives for each part new network id so i want to modify it as that all should have the same id and remove duplicate file .
could u suggest me how could i give for all network id that has common id as id 11 to get the same network id bcs all of them should be connected .
but i did not understand why it gives me three of id 11 .
he gives me 2 connected id network and seperately one network id and it is not connected with any another id any more in my table
@soly without an example I can't reproduce your issue. I've attached an example workspace. Perhaps you can modify that to reproduce your problem. If your line do not touch then NetworkTopologyBuilder will build separate networks for each feature. Perhaps you have duplicate features in which case you need to remove them.
network.fmw
network.fmw
sry for that but i have FME version 2018,could u provide me workspace for fme 2018 . thanks for ur reply
networkfme2018.fmw
Hi @soly, I converted the workspace that @markatsafe created for you to 2018 . Please see attached. There may be a difference in the parameters in 2018 vs 2020. For the best results in this case I would recommend installing the latest 2020 version.
networkfme2018.fmw
