InlineQuerier sql statement question (problem with case).
  • March 1, 2016
  • 85 views
Hello,
I have a following statement:
case when ($(DB_OPERATION) = 'INSERT')
then ( select max(uot.id)+1 as id, i.geometry_type as geometry_type, i.name as name, i.name as label, i.name as label_mask from unip_object_type uot cross join Inserted i)
else select * from Inserted i
end
When I run this in my workspace, I get the following error:
InlineQuerier(InlineQueryFactory): Error preparing database query: near "case": syntax error Unable to execute statement
InlineQuerier(InlineQueryFactory): Database was unable to prepare query 'case when (UPDATE = 'INSERT') then (
end
InlineQueryFactory instance was not properly defined. Consult logfile for details.
InlineQuerier(InlineQueryFactory): A fatal error has occurred. Check the logfile above for details
It has to be my mistake in the case statement. When I run the query just as
It works. However I need to run this query only when $(DB_OPERATION) (user parameter) is set to INSERT, when it is UPDATE, I need to only do select.
Any help is really welcome.
Thanks,
Radek
  • March 1, 2016
One thing I have tried was changing the word INSERT to 'INSERT' or [INSERT]... none of them works
  • March 1, 2016
Hi @drakez, as far as I know, CASE clause cannot be used to select a SELECT statement that should be executed. I would use a Tester to branch the data flow into two streams depending on the "DB_OPERATION" parameter value, and then use two InlineQueliers for each SELECT statement.
  • March 1, 2016
Hello and thanks @takashi!
My problem is - I know I can filter data based on DB_OPERATION value, however - I am trying to join two tables, where I have to use cross join (they have no common attributes). Any time I use cross join, even though one table basically does not exist, I get output data with "no_schema" - I need to have no output, not output with no_schema.
I have no idea if this clarifies what I am trying to do. When input is UPDATE - I need to merge two tables using some columns from original table, some columns from UPDATE table, when the input is INSERT, I am forced to use cross join (no common columns), so my inserted feature has id value based on max id from original table increased by one.
