Inline Querier ROW_NUMBER
  • September 8, 2017
  • 15 views
I need to use the Inline Querier to perform a row_number, at the moment I am getting the following error (I am using this syntax in SSMS and it is working):
InlineQuerier(InlineQueryFactory): Error preparing database query: near "(": syntax error Unable to execute statement
InlineQuerier(InlineQueryFactory): Database was unable to prepare query 'SELECT "Conf Score"
,"TOID"
,ROW_NUMBER() OVER (PARTITION BY "TOID" ORDER BY "Conf Score" desc)
FROM "Sheet1" '.
InlineQueryFactory instance was not properly defined. Consult logfile for details.
InlineQuerier(InlineQueryFactory): A fatal error has occurred. Check the logfile above for details
Best answer by david_r
The InlineQuerier is actually using an internal and temporary SQLite database, it doesn't connect to e.g. SQLServer (I mention this since I see you tagged your post with "sql server").
This means that you can only use SQLite-supported keywords in the InlineQuerier.
If you need to access your backend database, look into the SQLExecutor.
  • September 8, 2017
