Fast 3ds writer
sigtill
Forum|alt.badge.img+24
I have managed to create fast writer for many 3D-formats - except 3ds. I am writing a terrain model, buildings, roads, water, trees. I have tried combinations of MeshBuilder, Triangulator, GeometryCoercer, Deaggregator etc. However it seems that when writing to 3ds it still takes alot of time (6 hours, compared to 15 minutes with the approx 10 other 3d-file formats).
If I create the data to an IFMEMesh before writing I assumed the writing would go fast. I am using a FeatureWriter to start the writing at once.
I havent added any textures on the terrain model - so that does not slow things down.
Does anyone here have some tips with respect to this particular format?
@takashi
sigtill
  • November 28, 2017
@takashi
test
sigtill
  • November 28, 2017
sigtill wrote:
@takashi
test
Just testing the @takashi - mentions. Seems I have to switch to English language on my computer to get it to work.
  • November 28, 2017
sigtill wrote:
@takashi
test
Hi @sigtill, I received the notification from your post "test", but still have not received any notification from the next comment.
  • November 28, 2017
sigtill wrote:
@takashi
test
So far, I have no tips about how you can increase the performance of 3ds writer. How about contacting Safe support if it was critical in your project?
  • November 28, 2017
sigtill wrote:
@takashi
test
Can confirm, I also have to switch to an english keyboard for mentions to work. Seems that the text form overrides the AltGr-2 keypress and binds it to a heading style. Very annoying.
  • November 28, 2017
My keyboard setting is always Japanese (JP), but can you receive the notification? @david_r, @sigtill
  • November 28, 2017
Yup, I got your mention. I suspect the issue is that @ is mapped to AltGr-2 on most non-english european keyboard layouts. Since the forum software seems to intercept the AltGr-2 key press and redirects it to a h2 tag, the @ doesn't trigger the mention insertion code.
  • November 28, 2017
I've never seen the AltGr key, but now I've found what it is.
AltGr key | Wikipedia
It seems to be really annoying here...
  • November 28, 2017
Try pressing Ctrl-Alt-2 in the text box here and you'll see that it's mapped to a h2 tag (AltGr = Ctrl+Alt).
  • November 28, 2017
I see. :-)
