Create nodes where lines intersect polygons
  • November 21, 2016
  • 9 replies
  • 492 views
Hello, I am struggling to create nodes where lines intersect polygons. Basically, I have some points on a network and I need to create new points on the network that are 1 m away from that point. I thought I could buffer the original points by 1 m and then find where it intersects with the line (and then address the cases where it might intersect with other nearby line etc. later). However in the end results I got several additional points from the vertexes of the lines. How should I eliminate them? At the moment I use Bufferer -> GeometryCoercer to create line features, then do LineonLineOverlayer to intersect the network line and the buffer line.
erik_jan
Forum|alt.badge.img+26
  • November 21, 2016
The Intersector transformer should be able to do just this (use the Nodes output port).
To filter out intersecting lines and polygons (not line on polygon) use a Tester to see if line attributes and polygon attributes (e.g. LineID and PolygonID) have a value.
  • November 21, 2016
Thank you @erik_jan. Could you explain a bit more please? I tried the Intersector transformer but the nodes I've got still contain the nodes that I don't need, and I only got _node_number, _overlaps, _segments as attributes so can't filter them out based on ID. I only want the points where the circle intersects the lines so would really appreciate if you could point out a way.
  • November 21, 2016
Sorry I thought I had pasted the image but it appeared that I have not.
itay
Forum|alt.badge.img+18
  • November 21, 2016
Hi @hoangngoclan you could also try the LineOnAreaOverlayer as an alternative.
Hope this helps
erik_jan
  • November 21, 2016
Seeing this image it might even be easier:
Use the LineOnAreaOverlayer and the Lines output. This will result in the line segments inside the cricles.
Then use the CoordinateExtractor (index 0 for start and index -1 for end point).
If you need the points, use two VertexCreator tranformers for Start and End points.
itay
  • November 21, 2016
Yet another option is the TopologyBulider, see attached workspace.
create-nodes-where-lines-intersect-polygons.fmw
mark2atsafe
Forum|alt.badge.img+59
  • November 21, 2016
Yes, I think the Intersector is giving you the end points of the lines as nodes, as well as the intersection points. For me, I used a GeometryCoercer to coerce the circle into a line, then a LineOnLineOverlayer. The Point output port on that contains the point features you are looking for.
gio
Forum|alt.badge.img+15
  • November 22, 2016
Get the id's of the lines that meet at the point.
Then use a snipper to snip 1 meter of each line at both ends
Test wich snipped parts touch the node. (use PointonLine overlayer) Then snipp the endpoints.
( settings vertex, -1,-1 and vertex 0,0).
Test wich end points touch the node and discard those. (use PointonPoint overlayer)
The overlayers have tolerancesettings wich you'll need.
kathir
  • July 31, 2019
hi,
Can anyone explain how to measure the distance of intersected lines
