multiple delimiter in AttributeSplitter
  • February 11, 2016
  • 5 replies
  • 173 views
djmcdermott
Good day FME'ers,
I have a field containing string values which I would like to split on multiple characters. Each string contains one of more of "and", "&" and "," e.g. WORKSHOP AND PREMISES or SHOP, OFFICE AND PREMISES.
Is there a way to specify multiple characters in the delimiter or string row? The option for conditional values would be ideal here.
Thanks
Best answer by takashi
Hi, firstly replace all the possible delimiters with an identical delimiter string (e.g. "__delim__") using the StringReplacer.
  • Text to Match: AND|&|,
  • Replacement Text: __delim__
  • Use Regular Expressions: yes
You can then use the AttributeSplitter to split the resulting string using "__delim__" as delimiter string.
Forum|alt.badge.img+19
  • February 11, 2016
  • February 11, 2016
This regex may be better.
\\sAND\\s|&|,
djmcdermott
  • February 12, 2016
Thanks Takashi, Works a treat. It would still be nice to have this option in a single transformer though. Perhaps a list of values to separate on or a conditional using regex. E.g. IF \\d\\s ELSE ,
  • February 12, 2016
@djmcdermott, in fact, I published a transformer named "RegxAttributeSplitter". Find it in your Transformer Gallery: FME Store/Pragmatica folder.
gio
Forum|alt.badge.img+15
  • February 12, 2016
it is possible to use wordboundaries.
Tcl flavor in fme uses \\y
so \\yAND\\y
