GeoRSS Reader suddenly stopped working on FME Server - XML Parser Error
milo89
Forum|alt.badge.img+16
I've been using the GeoRSS reader to download data using FME Desktop.
Once this task become a daily exercise, it was uploaded and scheduled on FME Server and worked fine. However, a couple of days ago it started to fail showing an XML parser error.
54XML Parser error: 'Error at file:'C:\\Users\\P86357\\AppData\\Local\\Temp\\fmeengines\\VSW08446_Engine1\\FME_1580942504205_10336' line-1 column:13 message:attribute value expected'55attribute value expected56A fatal error has occurred. Check the logfile above for details
While in FME Desktop, it provides warnings at the same point but continues and succeeds.
2020-02-06 09:42:01| 1.4| 0.0|WARN |No extension handler could be found for an xml tag with prefix `' and namespace uri `http://www.w3.org/2005/Atom'
2020-02-06 09:42:01| 1.4| 0.0|WARN |The GeoRSS specification only allows for one geometry per feed item. Items with more than one geometry will be returned with aggregate geometries
I've tried using an HTTP Caller to download the XML and processing that way, it still fails on FME Server and works on FME Desktop.
Any assistance would be greatly appreciated.
Thanks in advance.
Be the first to reply!
