How do I remove white spaces before and after a "/"?
Hello,
I am working with an excel file with lots of field where I want to remove the space before and after a "/" eg. HWY 427 / North Queen St to HWY 427/North Queen St.
I have been testing using the String Replacer where Text to replace: is ([A-Z])([A-Z]).
Does anyone else have any suggestions?
Thanks in advance.
Best answer by takashi
Hi @1011analyst, try setting these parameters to the StringReplacer.
  • Mode: Replace Regular Expression
  • Text to Replace: \\s*/ \\s*
  • Replacement Text: /
  • November 1, 2017
erik_jan
Forum|alt.badge.img+17
  • November 1, 2017
HI @1011analyst,
Even though I believe @takashi has the better answer, this will also work:
I tried 2 StringReplacers (first replacing " /" with "/", second replacing "/ " with "/") as text replacement.
