duplicate text lines
This is kind of a weird question I know BUT I will ask it anyway.
I have a very very large DXF text file and have some duplicate lines of text  that I need to erase.
Here is a piece of the file as an example
Text_Northing=13333
1000
Name=Eastern Isles
1000
1000
1000
1000
Feature_Serial_Number=10156
1000
1000
Date_Last_Amended=19930101
1000
What I would like to do is to remove the duplicate  lines with "1000" in them so that the file looks like this
Text_Northing=13333
1000
Name=Eastern Isles
1000
1000
1000
The question is can this be done in FME. I have looked at the StringSearcher but cannot seem to be able to select more than one line at a time usiong the regular expressions
Any assistance would be greatly appreciated.
The text file is too big to run through a normal text editor.
Thanks for any help
Forum|alt.badge.img+19
  • May 6, 2015
This procedure might help you.
(1) Read the source file line by line with a Text File reader. Expose a format attribute called "text_line_number", which stores the line number (1-based sequential number).
(2) Filter the text line features by the line number to separate the 1st line from others.
(3) Send the 1st line to a VariableSetter to assign the text to a variable (store the prior text for the next line).
(4) Send other lines to a VariableRetriever to fetch the variable value (prior line text); send the text line which is not equal to the prior text to the VariableSetter to update the variable (discard duplicate text).
(5) Write the text into a new file with a Text File writer.
Takashi
  • May 6, 2015
Alternatively, the AttributeCreator can be used to get the prior line text. You can then select the text that is not equal to the prior line with a Tester.
gio
Forum|alt.badge.img+15
  • May 6, 2015
Or read the text file with txt reader, stringsearcher to look for "1000" and a variablesetter on the found port.
Calculate differentce in linenumber (wich you must expose on the reader).
Any difference=1 you dithc, rest you pass.
Reassemlbe the rows and reorder (sort) the records by linenumber.
  • May 6, 2015
Yup, there are several ways.
The PythonCaller with this script may also be effective.
# Python Script Example
class FeatureProcessor(object):
    def __init__(self):
        self.prior = ''
    def input(self, feature):
        text = str(feature.getAttribute('text_line_data'))
        if text != self.prior:
            self.pyoutput(feature)
            self.prior = text
  • May 8, 2015
Just wanted to say thanks to you for the great assistance
