I would need more details on the dynamic writer to speculate what's going on.
For the overlapping clippers one of the ways to do so is as follows.
Counter on the clippers to get a UniqueID
SpatialRelator with clippees as Requestor and clippers as Candidates, intersects, in the generate list include the UniqueID.
ListExploder (clippees), you now have multiple copies of the clippee features when there are multiple clippers that intersect it.
Clipper with Group-By set to UniqueID.
Note that this method is not advised when you also required processing of the Outside features of the Clipper.
The alternate method is:
AreaOnAreaOverlayer of the clippers (generate list, UniqueID) -- No more overlapping clippers
AttributeKeeper on the clippers to keep only the list of UniqueIDs
Clipper (Merge Attributes)
ListExploder (Inside)
Dissolver with a group-by set to UniqueID
Nice trick, problem solved, got exactly what I wanted, thank you very much!
Due to confidentiality agreement where I work, I can't upload my data online. I tried reproduce the rename error with some other data, and oddly I got it work. I'm going to test my data again tomorrow to find which parameter I set incorrectly.
