Attribute Trimmer Question
  • September 24, 2018
  • 10 views
I have a pressing deadline but I have no PERL skill and need this attribute trimmed - Lot/Plan(separators).
an example of an attribute:
1/AB842550
I am duplicating the column Lot/Plan(separators) into two columns - Lot and Plan
All characters to the left of this symbol "/" are the Lot numbers required in the Lot column
and
All the characters to the right of this symbol "/" are the Plan numbers required in the Plan column.
Any and all help would be greatly appreciated.
Thanks
peter
Best answer by hollyatsafe
HI @bananaspn,
You can use the AttributeSplitter with the delimiter as "/" which will generate a list with each component before and after the slash. Then use an AttributeCreator and set Lot as the first member of the list and Plan as the second part of the list:
Result:
HI @bananaspn,
Result:
