AreaGapAndOverlapCleaner : How to operate just between features and not inside the same feature
  • September 26, 2019
  • 20 views
Hello,
I'm using the AreaGapAndOverlapCleaner to clean some gaps in my data. However, the transformer shrinks the edges of some narrow polygonal water streams I have. How to make the transformer operate just between features and not in the inside of the same feature ?
Thank you.
itay
Forum|alt.badge.img+17
Hi @lianaolianov,
Are you referring to donut's ? because the holes are treated as gaps according to the documentation, unless the fill all gaps is set to no.
Hope this helps.
itay wrote:
Hi @lianaolianov,
Hope this helps.
Not referring to donuts but to slim features, for example, If I have a cleaning tolerance of 10m and and area feature slim < 10, the transformer shrinks it.
itay
lianaolianov wrote:
You could try and filter these slim features before cleaning the gaps > clean gaps > re-introduce slim features to the dataset.
Or use one of the priority repair methods.
