SQLExecutor error DECLARE CURSOR must not contain data-modifying statements in WITH? in FME 2020.1
skime
Hello,
I've a question about SQLExecutor and SQL statement. I'm upgrading workspace from FME 2017.1 to 2020.1 and in 2020.1 I'm getting an error in SQL WITH statement. In FME 2017.1 this code is not rejected and works.
Error with example
2020-07-22 14:35:49|   3.1|  0.0|WARN  |Error executing SQL command ('declare "public_custom_query_crsr" cursor for WITH something AS  (...)
INSERT INTO table (a...'): 'ERROR:  DECLARE CURSOR must not contain data-modifying statements in WITH
What has changed in SQL Executor from 2017 to 2020.1? The transformer version is the same as I see (version number 8). I use the same database
How can I change my SQL, is there a need to modify mine WITH statements?
Best answer by skime
I have a solution given by my SQL mastermind colleague (thank him!).
You need to close the cursor so... adding ";" before WITH is getting job done. 😅
  • July 23, 2020
Would it be possible to see the entire SQL command?
skime
  • July 23, 2020
Here you are, code example:
with insert_something as (
insert into table (attribute1, attribute2)
    select nextval(pg_get_serial_sequence('table''attribute1') ), $(FME_JOB_ID)
        returning attribute1
select attribute1 as attribute_old
    from insert_something order by attribute1 desc limit 1
skime
  • November 3, 2020
