IFMELine to CSV?
  • September 12, 2016
  • 18 views
I am quite new to FME Workbench, and am trying to extract some data from an AutoCAD DWG file to a CSV. The FME Data Inspector is showing the features I want to extract (autocad_<blah>), and it is also showing IFMELine information which I also need to extract.
The question is: How do I extract this IFMELine information?
What part of the geometry do you need to export?
CSV isn't a geometry-aware format as such, but you can convert your geometry into a text string using e.g. a GeometryExtractor set to OGC Well-Known Text.
Or you can extract e.g. the first or the last coordinate using the CoordinateExtractor, etc.
mark2atsafe
Forum|alt.badge.img+43
The CoordinateConcatenator is another transformer that might help.
