Change elevation
  • September 26, 2013
  • 5 replies
  • 139 views
I have some survey data incorporated into mapping data in a DGN. I need to change the elevation of the survey data within the DGN without affecting the mapping data. I know it is a long shot, but is there a feature in FME that will do this? Another issue is that the elevation change isn’t constant.
  • September 27, 2013
I probably don't understand exactly your actual situation, but in general, to set elevation (z-coordinate) to a geometry, you can use the 3DForcer transformer.
If you need to perform any other transformation, please describe it a little more concretely.
Takashi
Issue has been resolved. Thanks for your interest in trying to assist me.
I have a similar issue. I would like to add 100m to all elevation data in a DWG file but I'm not sure how to do it for all non-point features since the elevations are contained in many vertices that make up a single line.
I don't think 3Dforcer will help me because it only extracts the first elevation along a line, not all the elevations.
Does anyone have any tips?
Thank you
jdh
Forum|alt.badge.img+28
  • March 13, 2017
If you want to consistantly add 100m, I would try the Offsetter with a z offset of 100.
Thanks jdh, the Offsetter works
