Multiple short path with condition
  • January 24, 2025
  • 0 replies
  • 38 views
ohashkii
Forum|alt.badge.img+8
I am trying to find shortest distance from all points to all other points in my dataset.
the data set contains network lines and points
The points feature has only types (A,B).100+ points of typeA and 500+ points of type B.
Is it possible in FME  to have the short path finder to search the short path always starts from point A to pint B.
Then write the output to writer.
Be the first to reply!
