HOW CAN WE CALL PYTHON SCIRPT IN FME
HOW CAN I CALL A PYTHON SCRIPT IN FME, IT IS SIMPLE ONE CREATE A RANGE OF NUMBER AND WRITES TO A TEXT FILE IN RANGE LOOP
Best answer by deanhowell
Have you looked at:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pythoncaller.htm
deanhowell
Forum|alt.badge.img+23
  • July 7, 2020
  • July 7, 2020
deanhowell wrote:
thank you for the answer..
BUT NEED TO STUDY MORE FROM OBJECTS AND FUNCATION IN PYTHON.
It is not copy code from ArcGIS help and run it..
Forum|alt.badge.img+33
  • July 7, 2020
It's worth considering whether you need to use python at all, often things that you might use python in ArcGIS for can be accomplished without python at all in FME.
If you post more details on exactly what you want to achieve then people might be able to provide more help
  • July 7, 2020
thank you @ebygomm
i am trying to create a annotation layer in fme using python script below.. I want to use the label engine used by Esri. Below is sample code
import arcpy
arcpy.env.workspace = "D:/QC2017/contour/results/TEST1.gdb"
arcpy.ContourAnnotation_cartography("ONEMT", "D:/QC2017/contour/results/TEST1.gdb", "ELEVATION",2500, "ContourGroupLayer", "BLACK", "","PAGE")
Can we achieve this in FME.. without python script.
labeler is there but create to many label on the contour lines..
deanhowell
  • July 7, 2020
I agree with @ebygomm that it sounds like something FME could do. Can you share an image of the result you are trying to acheive.
