Geometry Extractor INVALID_GEOMETRY_VERTICES for WKT
  • October 17, 2024
  • 70 views
ben.dawson
I’m trying to make a KML from a CSV with Geometry in WKT. I have got up to the Extract Geomery transformer but keep getting the INVALID_GEOMETRY_VERTICES error. Example i’m trying to extract
LINESTRING Z (212197.02298451745 6343709.643456226 -405.22127891605567, 212199.2655298651 6343696.0119692795 -406.87294763726277, 212201.50807521114 6343682.380482333 -408.246661504635, 212203.75062055816 6343668.748995384 -409.3429700220356, 212205.99316590338 6343655.117508436 -410.1623117274895, 212208.2357112494 6343641.48602149 -410.7050143686031, 212210.47825659852 6343627.85453454 -410.9712950336693, 212212.7208019459 6343614.223047592 -410.9612602385047, 212214.96334728913 6343600.591560645 -410.674905969057, 212217.20589263522 6343586.960073698 -410.1121176798006, 212219.4484379844 6343573.328586748 -409.2726702479159, 212221.69098332908 6343559.697099801 -408.1562278832371, 212223.9335286767 6343546.065612854 -406.7623439939325, 212226.01318177005 6343533.424279183 -405.22127891605555)
Best answer by nielsgerrits
To make geometry from wkt you need a geometryreplacer, not geometryextractor.
I think you also need to reproject it, as kml is epsg:4326, before sending it to the kml writer.
nielsgerrits
  • October 17, 2024
ben.dawson
  • October 17, 2024
Thanks @nielsgerrits
nielsgerrits
Cheers :)
