@Scope_identity, @@IDENTITY or similar in FME
I have database with very much foreign keys. I need to recover last identity and put him in attached table.
For example:
I have table POINT (IDAN identity PK), and table SOME_POINT (IDAN FK).
Need to insert part of feature data into POINT and the rest into SOME_POINT. Of cource, I need to give them the same IDAN.
Is there a way not to use 'write into identity column' (because then I need to create IDAN by myself in FME), and even then get to PK and FK in these tables be the same?
Thanks!
Be the first to reply!
