Hello,
I have two questions about the HorizontalAngleCalculator transformer.
1) I simply need the AutoCAD Angle property of a line as shown below.
Is HorizontalAngleCalculator the best transformer to use?  Or, better yet...is there a way to expose this property in the reader?
2)  The install message for the HorizontalAngleCalculator says it’s not not created by Safe Software, but rather by “safe-lab” implying Safe Software Lab which is kind of confusing.
Can someone clarify what this means and whether the transformer is trust worthy?
Thank you,
Tyler
I guess this is not the autocad_rotation property?
You could use the LabelPointReplacer. This replaces the line with a word that is rotated on the line. Then merge this rotation back to the line.
I opened the custom transformer you mentioned and this is the main transformer inside i guess:
It extracts the coordinates of every line and calculates the angle in Rad.
@radToDeg(@atan2(@Value(_Y2)-@Value(_Y1),@Value(_X2)-@Value(_X1)))
I think AutoCad will calculate and display the angle if required. This will not be saved in the DWG file.
