Hello
I would like   to move the rectangle in the direction of  right side ?
fme 2021
thanks in advance
You can use the Orientor.
This will reverse the order of the vertices for the polygon. If the desired result is to move/shift a rectangle to the right (positive x direction) then an Offsetter should be used
