Archived
FTPCaller should be able to create/delete directories
Related products:Transformers
SagitAtSafe
moraalejandra93
fbastian73
alonzodlc
mark2atsafe
+1
  • SagitAtSafe
    SagitAtSafe
  • moraalejandra93
    moraalejandra93
  • fbastian73
    fbastian73
  • alonzodlc
    alonzodlc
  • mark2atsafe
    mark2atsafe
  • danielleatsafe
    danielleatsafe
wicki
With FME 2015 was introduced the FTPCaller which allows uploading data to FTP server from an attribute or file.
Some new ideas I 'd like to see in the next version of FTPCaller:
  1. It would be very helpful, if the transformer is able to create or delete directories on the connected ftp-server. So far, I have to still make it with PythonCaller-transformer.
  2. included Tester for FTP-conections. e.g.:
    a) for testing, if a special file or directory exists
    b) for testing, if the existing file is newer than the one i want to upload
    c) etc.
So far I 'm doing these tests with the PythonCaller, but it would be desirable that it is also possible with FTPCaller.
