Line Intersect
  • February 13, 2013
  • 33 views
Hi all,
perhaps this is a very simple question but I can't find the solution. I need to intersect two line feature classes, obtaining as a result only the intersecting line portions. This is the Overlay->Intersect tool in ArcGIS, but I can't find an equivalent transformer in FME. I tried the LineToLineOverlay  but it overlays all input lines, without distinguish between input and overlay features.
Thanks
sigtill
Forum|alt.badge.img+24
  • February 13, 2013
On suggetion:
1. Add a Counter to give each line a unique ID.
2. Run them through a Intersector.
3. On the NODE output of the Intersector - use a listexploder to make one feature per item on the list
4. Merge the Listexploder-features with the real lines (before the Intersector) to get the Geometry of the lines. Everything that comes out of the FeatureMerger_COMPLETE port should now be the lines which intersects. You might want to remove duplicate points etc
dustin
Forum|alt.badge.img+31
  • February 13, 2013
Use an AttributeCreator after each input line and overlay line.  Create a common attribute name between the two, such as 'intersect'.  Give a default value of 1 to the overlays, and default value of 2 to the inputs.  Feed both into the Intersector.  From the intersected port, run a test filter on the 'intersect' attribute to split them up again.
  • February 14, 2013
 To find identic common segments of two Line Features,  I use the "Chopper" with a Parameter-Value of "2"this splits Lines into their segments.  After that I use the Spatial Relator with a created Attribute("DE9IM=1FFF0FFF2") as Parameter to find exact identical line segments, but one can use "Intersect" as well, to find other types of Intersections, too. See Attached Workbench and Result-Picture. http://www.krimpenfort.org/fme/CommonSegmentFinder_nk_FME2012.fmw
