Last Saturday of the month
  • December 11, 2017
  • 9 replies
  • 119 views
dustin
Forum|alt.badge.img+31
Is there a function or method for returning the date of the last Saturday of any given month? Input attribute would be formatted 'April 2018' or 'September 2019'.
I'm currently doing this by manually inputting the correct dates in an AttributeCreator conditional statement. I'm looking for a method that would not require conitinual maintenance.
Best answer by takashi
Hi @cartoscro, assuming that the month is given with the format "<month name in English><space><four digits year>" (e.g. "December 2017"), this procedure does the trick (FME 2017.1+).
  1. Add "<space>01" to the month string to create a date value which represents the first day of the given month. e.g. "December 2017 01".
  2. Convert the format (%B %Y %d, in the example above) of the date to the FME standard date format (%Y%m%d).
  3. Add 1 month to the date to get the first day of the next month.
  4. Convert the format of the first day of the next month to the format of Sunday-based weekday number (%w), which is in the range from 0 (Sunday) to 6 (Saturday).
  5. Subtract (weekday number + 1) days from the first day of the next month. The resulting date is the last Saturday of the given month.
If you feel the workflow above is too cluttered, it's time to learn the lovely FME Date/Time Functions.
The Date/Time Expressions
_first_day_of_next_month@DateTimeAdd(@DateTimeParse(@Value(month) 01,%B %Y %d),P1M)_weekday@DateTimeFormat(@Value(_first_day_of_next_month),%w)_last_saturday_of_mongh@DateTimeAdd(@Value(_first_day_of_next_month),-P@Evaluate(@Value(_weekday)+1)D)
Hope this helps.
danilo_fme
Forum|alt.badge.img+45
  • December 11, 2017
Hi @cartoscro,
What do you wnat is similar like this ?
https://stackoverflow.com/questions/12796389/python-get-last-monday-of-july-2010
This was implemented using python.
Thanks,
Danilo
  • December 12, 2017
Hope this helps.
  • December 12, 2017
Hi @cartoscro
we now have PreviousSaturdayCalculator custom transformer available on FME Hub. Using @takashi's approach paired with this transformer, the workflow will be:
dustin
  • December 12, 2017
Hope this helps.
@takashi Thank you sir. It works brilliantly.
dustin
  • December 12, 2017
lenaatsafe wrote:
Hi @cartoscro
@LenaAtSafe Thanks!
dustin
  • December 12, 2017
I think I may have discovered a bug in putting this together.
For the month June and July, our output will be the full name. For all other months, the 3-letter English name will be output. So I assumed that for '_last_saturday_of_the_month', I could set a conditional value to format separately the two cases. However, I can't call on the 'weekday' or 'first day of the next month' attributes. Is this expected, or should I be able to access these from the conditional window?
  • December 12, 2017
Newly created attributes with an AttributeCreator/Manager seem not to appear in the conditional value setting dialog of the same transformer. If you need to refer those attributes in a conditional value setting, add another AttributeCreator/Manager to define that.
By the way, for June and July, the @DateTimeFormat function with the format specifier %b returns their 3-letter month name i.e. "Jun" and "Jul" as expected, in my environment - FME 2017.1.1.1. Which version of FME are you using?
dustin
  • December 12, 2017
Thanks for the reply. @DateTimeFormat function is working as it should for me. However, for those two months, my output needs to be spelled out completely. So my output months need to read:
Jan
Feb
Mar
Apr
May
June
July
Aug
Sep
Oct
Nov
Dec
  • December 15, 2017
I got it. I don't think there is any convenient Data/Time function to format only "June" and "July" in full name and format others in 3-letter name. However, you can change "Jun" and "Jul" within a date string to "June" and "July" easily with the StringPairReplacer after formatting all month names with 3-letter.
  • Replacing Pairs: Jun June Jul July
